http://www.yellowbullet.com/forum/showthread.php?p=9259493#post9259493Can you explain this for the EFI impaired?
cam specs will get you where timing should be on the stroke.
And just for reference (in Holley EFI software), a 0.0° Injector End Angle value, ends the injection event at BDC (Bottom Dead Center) of the intake stroke - before the compression stroke. This is 540° in the four stroke cycle (7th cylinder pictured above). A negative value moves the injection event before BDC, and a positive value moves the injection event after BDC. So a −180° Injector End Angle value will end the injection event at TDC (Top Dead Center) of the intake stroke (as the intake valve is opening). Obviously, a −90° Injector End Angle value will end the injection event in the middle of the intake stroke.
Excuse my ignorance but how would one know when the injector placement is poor?Injector timing has a greater affect when the injector placement is poor from my experience.
Correct. I tuned a solid roller with a IVC of 56* (596* Crank Rot.) It idled horribly, False lean cond, pump to start, Black soot on bumper, etc. Advanced Inj to 46* (10* under) and this resulted in a steady afr idle, nice throttle response. As said this has really no effect on wot.And just for reference (in Holley EFI software), a 0.0° Injector End Angle value, ends the injection event at BDC (Bottom Dead Center) of the intake stroke - before the compression stroke. This is 540° in the four stroke cycle (7th cylinder pictured above). A negative value moves the injection event before BDC, and a positive value moves the injection event after BDC. So a −180° Injector End Angle value will end the injection event at TDC (Top Dead Center) of the intake stroke (as the intake valve is opening). Obviously, a −90° Injector End Angle value will end the injection event in the middle of the intake stroke.
How does it Idle? Your IVC is 45* ABDC (585* CR). I have good results with Inj ADV to 10* under IVC. So, if I were having difficulty getting afr's right at idle or throttle response sucked, I would try raising Injector timing to 35*.Where would you start with this cam ? Also , what are you guys running for base pressure on the Holley 120 injectors ? ( 26 to 28psi of boost )
That'd be your transient fueling and fuel puddle issues. Some software allows this to be dealt far more extensively, but it it's not always so simple since we don't have OE-level calibration tools available.Injector timing has a greater affect when the injector placement is poor from my experience.
All setup are different so this is for testing. Don't blame me if your shit stalls. LOL
