Im getting closer and closer to start up and stuff keeps coming up with parts needed. Last night i put the upper intake back on and got the new TB put on and now i see i need yet another dam adapter harness to make this kit work. Im running a stock Ford TPS and the connection on the end of the Holley harness don't match up. Is there a simple adapter plug or short harness that will work? I don't want to cut up anything on the harness and would like everything plug and play. I went with the Chrysler style IAC so that connector was good on that but now i need one for the TPS. Thank you in advance! - Gene
