Have a hi ram I just put on the c5. Using the NX plenum spacer instead of my old outlet tb plate. Not much room to work with here as the thing is hanging out of the hood so I need to come up with a way to mount the solenoids so they have an equal path to both sides of the plate to feed the nitrous and fuel. I would like to hang them under the manifold and tee off the outlet to both sides. I am wondering if the hardlines would be enough to hold them if they hang upside down, or if I should model up brackets or a bracket to hold them in place. Curious what others have done (I am sure most will have a direct port on their manifold which will probably happen next season)
