If this correct what the ign should be doing. Seems like it should be pretty steady, but this shows all over the place to me..Running holley to control timing, msd digital 7 programmable for spark, box is zeroed out.
I would think the ignition timing should be steady. It is set at fixed 25 degrees to 600 to 3500 to see if it would stay steady, no change. Normally have it set at 20 from 600 to 2000, then 25 stepped up to 36 at 3500. Then 36 rest of rpm range. Or does this show a problem with the holley hall effect sensor trigged from the crank trigger.
http://s426.photobucket.com/user/altereddoug/media/idleigntiming8-23-14.png.html?sort=3&o=0
