Just when I thought I’d gotten the hang of this thing, the next one kicks me in the nuts. :smt088
LSX, with a Dominator EFI. It cranks, has a RPM signal but it won’t run. All it does is kinda softly burble fire in the exhaust, nothing violent or anything... Just a soft rumble.
58X, with a 1X cam sensor (set up just like my other car sitting right beside it) grounds to the heads, chassis, yada, yada. It will not even run when I try bank to bank mode. Fuel pressure/pump primes fine, I checked the color codes to the coils... They are OK and I’m using factory GM coil/pigtail harnesses. ODD going to ODD bank (1357) EVEN going to EVEN bank. (2468) Fuel pressure at prime= 45 psi.... Any thoughts? Could I have the fuel map that far off that it just won’t fire? I checked the plugs and they are not fuel fouled that I can see. Not wet or anything. Thoughts?
