1 - 3 of 3 Posts
Want to set this up on my car, only to use it for now to control timing while on the transbrake to build boost. Should I be using the same 12 volt input that im using for the 2 step and transbrake? And correct me if im wrong but while that input is triggered it will then look at the "fixed timing" that's in the boost builder function? Is anyone else using it, if so what do you have the parameters set at?
Just check the transbrake box. And it will only activate on TB.
I set mine to activate on 2psi and let go on 7psi. Then it will come up on converter a bit Before i cut timing out with fixed timing. I use 10 deg. But it depends on Engine. And if you are running a distributor or not.
1 - 3 of 3 Posts
