I went through a similar issue. I had a billet 24x wheel installed on my Eagle crankshaft. Also using Holley EFI. Anyway, the fucking thing would not start and was slipping in and out of sync while cranking. I was using the factory crank sensor, truck has less than 20k miles on it. Anyway, before tearing into complicated shit, I went to autozone and bought a replacement crank sensor. Threw it in and the thing fired right up. I then starting having issues with it loosing signal at 6500 rpm in boost and the ecu freaking out.
When LME installed the wheel on the crankshaft, it had a run out of .025". They told me that while they typically shoot for a better number than that, they assured me that it was well within an acceptable range and should work fine. Well, I later found out that .025" of run out is way on the high side. I chalked up the no start issue to be that the two crank sensor I had where just different enough for one to work and not the other. However, once I got into boost and 6500 rpm, the crank started flexing enough that nothing would fix it. Instead of pulling the motor down to find someone competent enough to install a new reluctor wheel, I just went to an external 4x flying magnet set up and all has been well since. The reason why I'm telling you this, it that I have seen first hand that a reluctor that is just on the verge of being out of spec that it can respond differently to different crank sensors.
