Hey guys I've been posting up over in the open/closed loop thread but I thought I'd start a new thread to keep that one focused on the CL issue.
I am getting random lean spikes (20-15 afr) during my runs and the CL comp is around 30% at times. Looking at my logs do things look normal. I have learning enabled but nothing is showing up in the learn table at all. All values stay at zero. When I first started with it I could see it adding or taking away fuel live in the table. It no longer does this. Not sure if that is a related problem or not.
Combo is a 393w with F1R Procharger. Car is about 3400lbs with a TH400 trans. Injectors are 80lb Siemens dekas. Wideband is the NTK sensor and I'm running cam2 fuel while at the track.
I tried to include most of the parameters so it may be hard to make out. Below is a link to the datalog file.
http://www.filedropper.com/hefilog20120606-202551
