On your data logs down track hace you seen any that drop off a couple pounds in pressure about 1/2 way into the run? I'm not using bleeds, have tried anywhere from 23 to 30 psi supply line preasure. Seems most of the time once I get to 6.5 psi flowing pressure or above this happens. If I flow at 5 psi with a 73 jet most of the time its stable the while run. I have put 3 pressure sensors to log data, one at pump outlet , one before rega, and one after rega. Supply line pressure is good withing a couple psi of starting, only one that moves is outlet from regulaator to solenoids. I replaced spring and diaphragm, same thing. I am going to replace regs next, nothing left.
