Are you sure it isn't the primary side that has no idle air bleed? I have seen them every which way, no IAB pri, no IAB sec, and no IAB in either one, but it is most common with no primary IAB. Nevermind all that, what it is ... it is, and it ain't right. Who knows what they were thinking.
The IJ is larger than it needs for most engines, .033" is usually OK with about .070" IAB. With 4 corner curb idle that will work as a starting point on both P and S. After you drive it some to learn what it wants, then tune the low speed level road with the primary IAB. It is best to not have any secondary T-slot exposed at idle.
The annular boosters have a stronger signal than down-leg so a smaller main jet than the same 850 body casting with down-leg boosters may be necessary. It depends on the engine and intake manifold, but PMJ as small as #74 is not unusual with annular boosters in that 850 body casting (1-9/16" venturi x 1-3/4" throttle bore). PVCR will still need to be determined after main jet is selected for best part-throttle A/F in mid-load vacuum above the PV opening point.
