1 - 12 of 12 Posts
I have an old pump that has sat in a garage for 10 years or more. I test it, it clicks once and doesn't run. I pull it apart and clean it up, and with the bottom cover off, It runs on the bench no problem. I put the gasket and cover back on it, and it doesn't run. :confused:
Any ideas?
T/S 368E
It's probably so weak the pressure from the cover is holding it??
Yes, it's a 10 year old Holley blue pump.
LOL, thanks. I'll give it a shot. Now for the replacement. It'll be used in a dedicated fuel system for nitrous. 500hp range. Would anyone like to recommend a replacement?
Aeromotive 150 or Mallory 140 (if you want something rebuildable).
The old Holley pumps (with blue or red motors) were decent. The newer one are a little less so, but probably better than a knockoff.
The Phantom Machinist
Push they Holley pump off onto a swap meet scrounger.
I put an Aeromotive 11203 in my Chevelle. Couldn’t be happier. 383 with a tunnel ram and 2x4’s. Fuel pressure is steady as a rock, straight up to 8200.
Checkout summits branded pumps. I replaced my two blue holleys with them.
I have one of those and it has been a good pump. I put it in when one of my blue holleys quit working. I figured if I got a season out of it I would be happy. 3 seasons and still working good. I have a Magnafuel regulator as well
1 - 12 of 12 Posts
