1 - 2 of 2 Posts
installing this kit on an lt1 with crank trtigger and 1x cam sync signal is there any way to run the ls coils with the universal mpfi harness or should i have ordered the ls1 harness and modified it to fit my build? thanks for the tips in advance.
Is there any way to run the LS coils with the Universal MPFI harness...
Holley 550-604N. Yes, you need the following harnesses:
The Holley 558-307 CNP main harness is for Holley's CNP smart coils and LSx coils.
If using Holley's 556-112 CNP coils, Holley's 558-312 CNP coil sub-harness is also required.
For LSx coils, the Holley CNP main harness plugs right into the two GM 12579355 CNP sub-harnesses.
There's no need to make your own ignition harness. This is much easier & a lot less time consuming.
1 - 2 of 2 Posts
