1 - 2 of 2 Posts
I've been looking for a throttle pedal assembly for a mustang, or universal, that is specific for a holley 4150 - has the correct ratios, pedal stops, and even has a throttle cable on it.
This is so I won't have to cobble anything together, and so it's just a mount it and run the cable kinda thing.
Thanks.
Fox body? Some were factory equipped with Holleys.
79-85 carb models factory cable. Doesn't have to be a Mustang. The cable on my 92 is from an early 80s Cougar. Last I checked, LMS still had new ones available.
If your intake has holes for the bracket, the factory piece can be used. Some aftermarket intakes (Performer RPM) require a small adapter.
If your intake doesn't have provisions for the factory bracket, there are aftermarket brackets that fit the factory cable.
1 - 2 of 2 Posts
