1 - 13 of 13 Posts
· Registered
Will a mini starter work to start my 572 BBC alcohol engine?
(about 13:1 compression. 38 degrees locked advance.)
If so - any particular mini you'd recommend?
· Confused Racer
You're not kidding. But I still only run an MSD 7AL-2 plus. So no cracking retard. Perhaps this winter that will be an upgrade. But for now I just need a strong starter.
Just add a retard box
· Registered
I wouldn't suggest you do that. It's another electronic item that can go wrong and to be honest it will eventually go wrong. Not many people still use those with the 2 box anymore cause of failures. Id rather just keep it locked and have a good starter. JMO
· Registered
Discussion Starter · #13 ·
1 - 13 of 13 Posts
