1 - 5 of 5 Posts
I was under full power and hit the t brake 3 times thinking I was up shifting. Pulled the engine down some but never locked up. Checked everything fluid is good all gears work and works fine on t brake. Curious if I should tear trans down to check, or just pull pan?
Th 400 trans. Thanks
It was in first gear. Only works in first. It's a rossler brake with a cap that moves in and out with application.
Ok thanks
1 - 5 of 5 Posts
