1 - 4 of 4 Posts
Technically, yes. The brake valve is hydraulically loaded, so the spring has zero effect on release. The spring makes the solenoid move out when the car is not running. If you need a replacement, the modulator spring used in shift kits for T400 or T350 is the same.
I've had one for sometime works as advertised, I'd even venture to say better than the high dollar one I had before. He's a racist but, that don't make him all bad tho...
1 - 4 of 4 Posts
