so when i got my car out at the end of season i was having a pretty bad high rpm miss..i had just put a new carburetor and fuel system on it so i thought it was fuel..i upped the fuel pressure and re -checked floats and it made it better but still did not pull after 6k and started to miss at about 6500 ( should of been good to around 7300 per cam)
-considering i had to run a bone stock 10 inch paper air filter i figured that might of been my problem-getting choked out at the high rpms.i had since turned it in for the year and was just hoping by putting a scoop on over the winter would fix the problem..
-well, i decided to have the motor freshened up so when i was pulling the motor apart i noticed the exhaust valves were kissing the pistons..every piston has a very very fine nick the shape of the exhaust valve...think i found my problem?
