1 - 10 of 10 Posts
I watched one of Steves videos and he pointed out a hidden leak,so i thought next time ive got the pipework apart ill take a look,so doing the lash i had the pipework off looked inside and there it was,hole drilled right though,so i cut a bolt down and slotted it and put a tad of silicon on it job done,i think i remember steve saying this is common on F2s & F3s .
been there done that!!!:rolleyes::cool: fought that problem a few years back... was a glad mofo when i finally found it!!:D
Cheers Mark I'll check mine.
Tony McKellar
What sort of difference did this make?
I usually just weld that hole up myself. Or you can set screw and locktite it in or if using a short enough set screw double lock the set screws to one another with plenty of locktite. On my motor that hole was worth 2 pounds of boost and somewhere around 60 HP.
dam, all the Prochargers i have had, never thought to look for something like that-thanks for th tip
1 - 10 of 10 Posts
