1 - 4 of 4 Posts
we have a tsi trans in our 98 firebird, there only about 3 full passes on this trans since it was rebuilt by transmission specilties last fall, first outing no issues at all with trans had 1.30 60 ft spinning at 40-45 ft out . yesterday at the track did the burnout did fine staged the car let off the button and the the car lounged backwards backed the car up did not want to pull through first towed it back to the trailer checked linkage it checked good any ideas what may have happend and what to check ? valve body, trans soliniod, sticking spool in trans any help will be appreciated thanks
Low band smoked....Check band adjustment!
Possible bad, leaking orings / lip seal on low servo if so equipped, they may be metal rings instead of rubber orings..
1 - 4 of 4 Posts
