1 - 2 of 2 Posts
I'm starting my set up for the first time 540 w f2 endrele 80a and my fuel pressure is almost zero at idle and 80 when I hit the gas I have Weldon reg fast efi I'm wondering if my fuel pressure needs to be 42 all the time or just at max rpm or do I need a differnt pump..t he motor runs with a little shot of carb clean to get it going but pops through TB like the timing off but the fuel pressure is Al over thanks for the help
Carb cleaner usually kill an engine, and a pop is usually lean. 0 fuel pressure sounds like it need adjustment to whatever fast specs it should be. Hope this helps
1 - 2 of 2 Posts
