I've had ladder bars in my car for about a year. I played with shock adjustments, launch rpm and tire pressure to find a spot where the car would launch.
In order to get the car to hook I needed to set the launch rpm on my two step way down 2000rpm (4750 rpm stall) and adjust the bump on the rear shocks to full soft.
I'm thinking I need to move the front pivot on the ladder bars up one hole in order to get more hit on the tires so I can get the shocks into an adjustable range and up the launch rpms.
Any suggestions, am I on the right path?
