Ran at National Trail this weekend. Track had decent amount of rubber. Never saw any spray. Track temp around 130 degrees. Car weighs 1800lbs front/1500lbs rear. 36" ladder bar in the lowest hole. Low run 10.5x31w M/T w/tubes, foot brake. Tried varying the starting line rpm from 2600-3200 Had the front shocks full loose. Loosened rear rebound and tightened rear compression on the rear shocks. It just wadded the tire. It starts to pitch rotate. Wheels are up maybe 5" for about 15 feet. I can feel it shuddering the tire. tried air from 12.5-14psi (normal 13.5). Low air just wads and folds the tire. I got it somewhat consistent, then bam spins. When the track is a little cooler it'll go mid 1.2x 60 ft. I wasn't the only car having trouble. We run index. I probably should have slowed it to 9.25. But even with the weather it had enough power to get to 9.00. Day 2 was cloudy. Run 2 was out of the groove. Run #3 broke a trans cooler fitting. Any ideas?
Doug
Doug
