1 - 4 of 4 Posts
I have a truck and the ecu is showing codes cdu219 and ecu128. Anyone know whay they are. Any help is much appreciated.
Thanks Tino.
Those codes are not fault codes they are module identifiers. Ecu128 is the engine module meaning that the engine is reporting on the datalink that it has a fault. If I remember correctly the cdu219 is for the Vorad module but I am not positive. You are going to have to pull the actual fault codes for anyone to help you.
What year and model truck is it?
219 is the MID for the Vorad module like I thought it was. It is not a fault code. Depending on the model truck and what dash he has he can either get the PID, SID, and FMI from the dash or the flash code from the check engine light.
From the Eaton fault code book:
MID 128 - Engine Pg
CAT . . . . . . . . . . . . . . . . . . . . . . .2
Cummins . . . . . . . . . . . . . . . . . . .3
Detroit Diesel . . . . . . . . . . . . . . . .8
International . . . . . . . . . . . . . . . .12
Mack . . . . . . . . . . . . . . . . . . . . .16
MID 130 - Transmission
Eaton AC-AS1 . . . . . . . . . . . . . . .17
Eaton AS2-ASX . . . . . . . . . . . . .18
Eaton ASW . . . . . . . . . . . . . . . . .19
Eaton CEEMAT . . . . . . . . . . . . . .20
Eaton CEMT . . . . . . . . . . . . . . . .21
Eaton DM2 . . . . . . . . . . . . . . . . .22
Eaton Lightning . . . . . . . . . . . . .23
Meritor FreedomLin . . . . . . . . . .24
Meritor SureShift . . . . . . . . . . . .25
MID 136 - Brakes (ABS)
Bendix Tractor ABS . . . . . . . . . .26
Eaton Tractor ABS . . . . . . . . . . .29
Wabco Pneumatic Tractor ABS .32
Wabco Hydraulic ABS . . . . . . . .34
MID 137 - Trailer (ABS)
Bendix Trailer ABS . . . . . . . . . . .35
Eaton Trailer ABS . . . . . . . . . . . .37
Haldex Trailer ABS . . . . . . . . . . .39
Wabco Trailer ABS . . . . . . . . . . .41
MID 142 - Engine
Mack . . . . . . . . . . . . . . . . . . . . .42
MID 158 - Engine
MID 219 - VORAD
Eaton VORAD . . . . . . . . . . . . . . .43
1 - 4 of 4 Posts
