1 - 3 of 3 Posts
im about to do a 5.4 4 vavle swap in to a fox i want to do a carb set up and i just wanted to no what all i need to get for the swap and a idea of what it will cost thanks
First off a BIG hood. Carb and mod motor equals a pretty huge cowl. Probably 6" or bigger.
-you'll need a sullivan lower intake.
-A modified DS valve cover that accepts the distributor.
-a fox/mod motor k-member
Thats just for starters.
http://www.modularmustangracing.com/
Scroll down almost down to the bottom and they have the valve covers.
Sullivan discountinued their 5.4 intake. So you would need to source a used one or custom one. Also can use a MSD mod 6 iginition box that fires the COP using the oem crank and cam sensors
1 - 3 of 3 Posts
