1 - 2 of 2 Posts
i have 2 simple questions for you guys but it confuses me tho
ok im going to try to explain this best i can so bare with me
1.)
it pertains too how an wideband o2 censer hooks up, it gos from the gauge to the exhaust pipe but iv got an megasquirt cpu for the car too run it just runs off of one o2 right/?? so i can keep the stock o2 unhooked as long as the wideband is hooked up to the cpu right? is there special hookup for this to work or what?
2nd question also simple too u haha
sense iv got the new cpu im running Delphi 75lb injectors low Impedance compared to the stock brown tops of 35lbs
i cant run the 75s it floods it out "running stock ones now"
in the tuning of the cpu where should i be looking too change how it pulses??
The o2 should plug into the megasquirt harness , you should mount it 8-18 in from the turbo exh housing. You need to get the o2 sensor in so you can change your target a/f at idle. You can also lower base pressure.
1 - 2 of 2 Posts
