1 - 3 of 3 Posts
what to do? I run bracket, and the track is good first run in the morning, and then goes bad, through the day.
60 feet times
1 run 1.46
2 run 1.55
3 run 1.56
4 run 1.58
it affects the elapsed time from 10.82 to 11.05, and for bracket this is killing me, need help, I don´t have much knowledge in suspension setup,
1974 nova, 416 l92 engine, powerglide with transbrake, 5500 rpm converter, 3.92 rearend gear, 28x10.5 m/t slicks, in front moroso trick springs, compeng adj shocks, back caltracks bars, split monoleaf springs and rancho adj shocks,
basic setup is caltracks just touching the spring, rancho in the 5 position.
How I can make the car run the same every race with the changing track conditions?
what is the best to do?
thanks to all
What type of tire are you running...slicks I assume?
have someone video the car for the first 60 feet on several passes from different angels so yoy can look at how it is reacting at the hit. If you can post the video on here and i am sure some of the more knowledgable members would help you out with it.
1 - 3 of 3 Posts
