coal or wood tar works the best...factWhat type of psoriasis is it? Most of the better OTC treatments include salicylic acid, up to 3%. That seems to work the best for me for plaque psoriasis.
tell her to try this...http://rawleighantisepticsalve.blogspot.com/2011/02/rawleigh-antiseptic-salve-and-skin.htmlGood luck. My wife has it on her scalp, elbows, back, legs, in her eyes and around her eye lids on very bad flare ups. She has tried everthing known to man and it has never "went away"... Colbetasol and Halbetasol cream and solution seem to work best for her. Good luck with it.
My dad used old motor oil to treat mites on his birds. I would almost be willing to go with an old school treatment over a new world one.coal or wood tar works the best...fact
Yup..posion oak or ivy gets in blood stream if i touch it...mama would put ralweigh sauve on it and bam it was gone....its hard to get nowMy dad used old motor oil to treat mites on his birds. I would almost be willing to go with an old school treatment over a new world one.
Not sure on the type....it doesn't itch. What brand of OTC salicylic acid do you use?What type of psoriasis is it? Most of the better OTC treatments include salicylic acid, up to 3%. That seems to work the best for me for plaque psoriasis.
While plaque psoriasis may look like just a skin condition, it is in fact a disease of the immune system. The immune system protects the body from infections and diseases. In patients with plaque psoriasis, certain immune cells are activated and play an important role. They overproduce inflammatory proteins such as tumor necrosis factor (TNF). These proteins can cause skin cells to grow too quickly. The skin cells build up and form raised, red patches often with a silvery scale, known as plaques. These plaques may itch, be painful, and can bleed. Topical treatments may relieve symptoms, but won't stop the disease. Use whatever works for you.....fact.coal or wood tar works the best...fact
Mine started that way too....progressed to itchy patch. Hopefully yours won't. You can pretty much pick anything from the drugstore that contains salicylic acid in combination with skin conditioners to relieve it, check the ingredients and pick one, pretty much.Not sure on the type....it doesn't itch. What brand of OTC salicylic acid do you use?
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2945847/While plaque psoriasis may look like just a skin condition, it is in fact a disease of the immune system. The immune system protects the body from infections and diseases. In patients with plaque psoriasis, certain immune cells are activated and play an important role. They overproduce inflammatory proteins such as tumor necrosis factor (TNF). These proteins can cause skin cells to grow too quickly. The skin cells build up and form raised, red patches often with a silvery scale, known as plaques. These plaques may itch, be painful, and can bleed. Topical treatments may relieve symptoms, but won't stop the disease. Use whatever works for you.....fact.
Not disputing that it is in use, according to your quoted article it is best used for certain types of psoriasis, and is better for certain parts of the body. If it was the best for all, there wouldn't be many other treatments made and sold. I could quote the same type of published material for other treatments, as I said above, whatever works for you, is the best for you. Coal tar didn't work for me, I tried it for a good while before looking for something else.
Thanks for the advice, but I'm fat enough already.Might not help you ..but i found if i eat maple syrup on waffles and pancakes every other day, mine goes away and stays away
