1 - 5 of 5 Posts
This is a chasis dyno pull I had done a while ago.
Is this graph normal? I'm concerned about the drop around 5800rpm's and the rough and bouncing curve.
Combo is a
406 13:1 Afr 210
super vic 950hp prosystems carb
.645/lift 276/[email protected] .050 108 cl
7531 ignition NGK 9's
Air fuel ratio was 13:1
Any help is appreciated
[/IMG]
Seems real choppy for the smoothing factor on 5. Chassis dyno's are weird tools. What was the torque? Did you have slicks on the dyno? Seems like you have your A/F close. Just take it to the track,MPH will let you know how it is really doing.
Is it the dyno's brake overacting? Thats what it looks like.
1 - 5 of 5 Posts
