Like the title says-any alternative to QA1 shock oil? TIA!!!!!!
E eb02z06 · Registered Joined Oct 15, 2007 · 870 Posts Discussion Starter · #1 · Sep 30, 2011 Only show this user Like the title says-any alternative to QA1 shock oil? TIA!!!!!!
85montess · Registered Joined Jun 25, 2008 · 70 Posts #2 · Sep 30, 2011 Only show this user For my piece of junk Art Morrison front struts, I used motorcycle front fork oil when I had to repair the seals.
B Bbarsh · Registered Joined Nov 12, 2006 · 458 Posts #3 · Oct 1, 2011 Only show this user Suspension fluid comes in many different viscosities. If you put the wrong weight oil in it it will be the same as changing the valving.
