1 - 7 of 7 Posts
3250# ×275 f1r. Left @ 3500 rpm. the front suspension is tied down to 2.5" of travel with strange single adjustable struts set at 6 clicks. Rear shocks are qa1. rebound is at 16 clicks and compression is at 20 clicks out of the possible 30. Lower control arms are 100% horizontal. wild rides upper torque plate, using the middle hole.58.65% of weight on front tires.
http:// Xtreme outlaw 275: http://youtu.be/zbd1IsvnSQo
Sorry in advance for the long video.
If you don't want to invest in a killer front shock, I think a lot of Mustang guys are only running like an inch of front travel. Personally, I would rather have the shocks....just another tool to tune with.
I think your front struts have 10 settings or clicks from softest to firmest. You said you're at 6 clicks. Try 9 and firmest 10 settings. Looks to me that the initial Launch is good but the front end comes up just a tad to quick.
1 - 7 of 7 Posts
