Does anyone know the exact height difference if I take my top end and stick it on a 10.2 block with the intake spacers???
Trying to figure out if my hood scoop will still fit if I make the change to gain a few inches.
I know the deck height is .400 more, but how much is the vertical height .200, .300 or ??
Just checked a BBC engine block blueprint for actual height of the block itself and not the deck height. With an actual height of ~10.85" on the short deck and ~11.03" on the tall deck according to this, I don't see there being that big of a difference in the end. 1/4" at the most, going by that specification plus a few thou
Thanks again Guys.
I was pretty sure it would only be a couple of tenth's, but wanted to ask in case I had a brain fart.
There should be plenty of flex in the carbon fiber.
Trying to re use the old stuff until I switch to a 14* and then I'll buy a modern scoop and spend the dough building a new pan
instead of the old style soop I've been running all these years.
