1 - 3 of 3 Posts
Bracket racer
What's the best combination of springs to get your initial timing around 20-22 degrees, and total around 36-38, preferably all in by 3000RPM? This is a Mr. Gasket curve kit....all the chart they provided does is confuse the hell out of me. Vacuum advance will NOT be used.
Iam not sure on the colour as I haven't used these for along time I just locked out my HEI but I would thing the weakest one that's what I use to use timing was all in by around 2700..not sure if this helps
1 - 3 of 3 Posts
