1 - 11 of 11 Posts
It's that time again.. Knoxville Dragstrip in Tennessee will be having their monthly Heads Up/Index program June 9th. Pro Street, Cheap Street, 7.00, 6.00, 5.70 & 4.70, rules can be found on their web site www.knoxvilledragstrip.com ...
Discussion Starter #2
**RULES**
PRO STREET
Head up Pro Tree .400 Qualified Pro Ladder All cars must weigh after all qualifying rounds and elimination round wins.
Tire –
*10.5W -x31 max Backhalfed chassis only No full tube framed cars! Must have funny car cage.
*No complete fiberglass or composite body unless OEM equipped. Aftermarket bolt-on front clip allowed. (If equipped w/bolt on front clip from factory)
*Aftermarket front suspension components allowed in stock location. (On factory frame rails) Cars originally equipped w/struts must mount the struts in original mounting locations.
*Must have mufflers. (Except turbos)
*Must have working taillights and headlights.
*Lexan windows allowed.
*Fiberglass limited to doors, trunk, hood, fenders, bumpers.
*Must have stock appearing dash.
*No screw blowers allowed!
*No C.I. Limit
SAFETY-
*Helmet, jacket, pants, neck collar, gloves required
WEIGHT-
*Small Block
N/A – 2,500 lbs.
Turbo – 3,100 lbs
N20 – 2,700 lbs.
Twin Turbos – 3,150 lbs.
Blower – 3,100 lbs.
ADD 100 lbs. each additional stage
*Big Block N/A – 2,800 lbs.
Turbo – 3,200 lbs.
N2O – 3,000 lbs.
Twin Turbos – 3,250 lbs.
Blower – 3,200 lbs.
Add 100 lbs. each additional stage
NOS Cars Only
Tire Size 33-10.5 W
*Max For 4.840 Motor Bore or Smaller & 706 Cubic Inch or Smaller Only Can Run 33-10.5W Tires. 3100 lbs.
*1 System 3200 lbs.
*2 Systems 100 lbs. per System after 2 on 5 inch Bore Motor 706 Cubic Inch or Larger Have to Run 31 Inch Tires Maximum
CHEAP STREET
Head up Pro Tree .400 Qualified Pro Ladder All cars must weigh after all qualifying rounds and elimination round wins. Tire –
*10.5W -x 28 slick non W or 275 radial max
*All steel body (Hood, Trunk, Bumpers can be Glass)
*Full cage required
*Stock appearing Full frame rails front to back 9Notching OK, Minitub OK)
*Must have carpet and both front seats (No Exposed Sheetmetal)
*NO FORWARD FACING SCOOPS Unless factory equipped
*ALL LIGHTS & TURN SIGNALS MUST WORK!
*Mufflers required (Unless Turbo)
*No Wheelie Bars
ENGINE-
*All cars must run cast intakes OEM composite NO SHEETMETAL INTAKES ALLOWED
NITROUS-
*4 line (bottle to solenoid)
*1 stage only
*small block allowed fogger
*big block plate only
*2 nd . System must be off car, or solenoids removed
*NO METHANOL ON ANY COMBO!
BOOSTED-
*Superchargers limited to rib style belts only (NO COG style belts) Turbo limited to 76mm, no air to water, no methanol injection No twin turbos, superchargers, or dual power adders of any kind! Turbo & Superchargers small block only!
SAFETY-
* Helmet, jacket, pants, neck collar, gloves required
WEIGHT-
*Small Block N/A – 2,800 lbs.
Turbo – 3,300 lbs
N20 – 3,100
Blower – 3,300
*Big Block N/A – 3,200
N2O – 3,400
Any car that exceeds 5.40 will have weight added for next round. (100 lbs. Per tenth) & If you go 5.40 or faster in the eliminations, you will carry the weight over to the next race
4.70 Top Sportsman Rules (IHRA)
5.70
SAFETY-
*Helmet, jacket, pants, gloves, neck collar. (Arm restraints required if open body)
*Full cage required.
6.0
SAFETY-
*Helmet, jacket, pants, neck collar required.
*Full cage Door cars only!
*No Throttle Stops!
7.0
SAFETY-
*Helmet, jacket, pants required
*6 pt. Roll Cage Required Door cars only!
*No Throttle Stops
Bryan, just know him from racing over the years. My dad worked with his former driver Terry Housley for years at the Y12 plant in Oak Ridge. Never had a problem with TJ and i consider him a friend if thats what your asking. BTW....any info on that 4.70 race we talked about @ SGMP in Sept?
yea some info its looking good i should have news for sure within the next two weeks.. what i was askin is they are some rumors about tj buying another track
Discussion Starter #6 (Edited)
I haven't heard anything about him buying another track, but I can ask him next weekend. I wonder if it could be the one that was started & never finished in Sweetwater?
Discussion Starter #9 (Edited)
I know some YB members have cars that fit into the Pro Street & Cheap Street classes, both of these classes need some car count. Last month Cheap Street only had 2 cars. The 6.00 & 7.00 index classes always have good car count and 4.70 generaly have 8-10 cars. Always welcome more cars in all classes. It would be awesome to see a 16 car field in Pro Street, Cheap Street & 4.70... How about it YB, anyone feel like coming to Knoxville :smt102?
This is the only picture I could find of the track.
1 - 11 of 11 Posts
