I think the exhaust ports are raised liked 3/4" over conventional heads, it is the standard spacing just raised ports. You need to check all of your clearences to make sure that it won't hit your steering or on the bottom of the frame from actually raising them up to a higher location. You could call Lemon's headers and tell him what you have and he could tell you if it will work. Good luck. Michael
