1 - 13 of 13 Posts
496" BBC, F-2 15# boost, 7500rpm on E85. What would be the minimum header tube diameter? Would a set of 2" headers be okay?
Hi Steve I had 2 inch hooker super comp headers on the nova at 18 lbs and it worked ok,Lemons made a set of 2.5 inch and they definetly made more power at 23lbs of boost.They told me that on these boosted engines you cannot go to big.
Mine are 2.5 inch with 5 inch collector on a 540/F2.
Thanks guys, as much as I would like a set of zoomies, I doubt the local cops would let me drive it on the street like that! LOL
Depending on what car its in, you can usually buy 'off the shelf' headers up to 2-1/4". Most aftermarket BBC heads need a 2-1/8" header just to clear the exhaust port and not block it. That's what I'd go with if it were me and price was an issue. If you want / need something custom built, like Lemons, Kooks, etc., then you might want to go a tad bigger but I'd ask the builder first. Its not like losing a little low end torque is a big deal. :)
I have 2.5 inch with a 509 but more boost. If you are buying/building and plan on bigger in the future, I would go 2.25 minimum. Hell I had 2" on a 347 SBF and they worked well and was still an animal down low. Like 68 Bird said bigger the better and loss of down low torque isn't usually a problem on a blower car.
I don't think on a supercharged motor that you can put to big on it (within reason) it doesn't use the scavenge effect that a NA motor does. But to small can hurt performance.
I have hooker super comp's 2in on my bbc 477 with 19lbs of boost seems fine I would like bigger but for a g body they were the cheapest. Everybody else was two times as much
1 - 13 of 13 Posts
