1 - 20 of 24 Posts
What type of gaskets do you guys use??Copper, steel core gasket or just silicone.
I have Avenger 230CC-R with stock header gasket bolt pattern so im restricted of a decent gasket..A lot of the ones i trye3d i've had to port them out and they keep blowing out every 12-15 passes.the flange is 1/2 thick and is not warped.
Any options???
Any options???
Silicone ;)
High temp red or I've had good luck with Right Stuff. Key is a straight header flange. What's nice is nothing to compress so bolts don't loosen up.
I've been using Cometic header gaskets. Work badass as long as your header flanges arent warped to crap.
Silicone
REMFLEX... Trust me... Nothing else comes close.. Far and away the best I've ever used..
Loose header bolts.. Warpped flanges.. They seal everything..
cometic work great
Discussion Starter #15
where do i get this at??? I just had another set of gaskets laying around so i put them on with copper spray.we will see how that works and if it blows i will switch..
1 - 20 of 24 Posts
