I have a 1984 Camaro that is running 11.71 at 115 mph. I would like to get a little more out of the setup and was wondering what you guys think. The setup is...
355 10.5:1 compression flat top heads
Vortec heads
288hr cam, .520/.540 lift with 236/242 duration
1 5/8 in headers
edelbrock performer rpm intake
BIGS custom 750 carb
dual 2.5" exhaust with an x pipe
28x10.5 tire
Moser 9 inch with 4.11 gear
3200 lbs with me in the car
th350 trans with 9.5" 3500 stall converter
36* timing
I am running really good times for stock vortec heads and I am very pleased with the setup. Just looking to get a little more and came across a good deal on some afr 195 1054 heads that are 60cc. The 60 cc from 64 will bump the compression up a little bit which will help as well. But I was just wondering do you guys think these heads will be worth the swap and net a noticeable ET gain?
Vortec heads
1 5/8 in headers
28x10.5 tire
36* timing
