1 - 6 of 6 Posts
Premium Member
What gasket would you guys use for a small block chev with 18 psi of boost? I am doing a refresh I was thinking a set of Fel Pro Mls just for the safe side.
Im using the SCE head gaskets Part number S11204 no o-rings in block or head 25lbs of boost no problems. I first used the Fel Pro MSL but I could not get them to seal they kept leaking antifreeze between the block and the head on the out side of the block between number 1 and 3 cylinder small block chevy. Pulled the head off after trying for 5 days. Then installed the SCE gasket no problems. Maybe i was doing something wrong.
I've had good luck with the FelPro MLS on my BBC with up to 25lbs of boost.
Custom Engine Shop
Fel Pro MLS will will make sure they are the black coated gaskets.
1 - 6 of 6 Posts
