1 - 6 of 6 Posts
I am going to install some drain lines from the back of the head to the oil pan but i was wonedring what size fittings and lines do you run? I was going to tap the head for a 3/8 pipe and run #8 line. In addition, where in the pan do you run the lines to? In the sump or above? I was thinking above.
On my one engine I used #8 in the front and rear of the heads and returned just under pan rails, but if I was to use two only at the rear I would consider #10s...........
-8
1 - 6 of 6 Posts
