41 - 60 of 212 Posts
One thing of note when I talked to the rep is that he said the injectors are boost referenced also and could run at higher psi then the 58lbs upwards of 75 lbs . That makes me wonder if an external reg is used it probably has to b boost referenced also.
Wouldnt you have to bypass the stock regulator?
Just picked up the last power adder4 in the country looking to blow through a stock small block in the next few weeks. Very intrested in other setups with fitech hardware
I'm the guy on the turbo forum with the 9 second camaro with the fitech system, rwhp was 810 hp thru a 4l80 and a 12 bolt, 3950 with me in it, 16 psi boost on 112 octane with a sbc. The system works pretty well, I originally built it with blow thru carb, got tired of messing with the carb.best so far is 9.75 with traction issues
I can't figure out how to quote on here, but as far as the fuel side of it I dual feed the throttle body, deadheaded, off an aeromotive regulator set to 60 psi that returns the fuel just like a carb bypass setup and I don't use their regulator or return. I think I'm running 80% duty cycle rite now, and it's probably close to 1k crankshaft hp.
I haven't opened the unit up to see what the injectors look like, I figured I'd pull it apart this summer when it's too hot to run the car and drop the injectors off at my injector guy to see what can be done. One word of caution concerning fuel pumps, this system runs a base pressure of 58, add 16 psi boost to that and you are at 74 psi. I found that most fuel pumps wouldn't cut it, as the volume drops off alot, aeromotive didn't even want to recommend a fuel pump for it. I talked to magnafuel and wound up using the pro tuner 750 pump, the fitech can pwm the pump output, but not over 14 amps. I need to get a solid state relay and use the pwm function to keep the fuel cool for street use.
Looks like they went for a pretty small injector to need 58 BP, must be like an 80pounder, if the ecu manages to run 160s or even better 220s it'll be amazing self tuning 1300-1500 hp carslol
It learns pretty fast, I have an innovative wideband in the car. When you change the boost setting on the first pass the wideband moves around quite a bit, on the second pass it stays at 11.5. My fuel mileage went from 14 with the qft 750 blow thru to 20 mpg, car is mostly street driven. I run on leaded fuel at the track, and pump on the street, sensors are working fine but they are a change out item on leaded fuel
I run twin walbro 400s at 60psi non boost referenced through 8mm OEM feed and return lines. Supported 18psi on gas with a 10.8-11:1 a/f with no sign of nearing the limits. Seems like that setup would be applicable to this system. Two pumps are less than $200 total. PWM controlled through the ECU though
its probably not making 1000 but 138mph @ 3950lbs is still pretty impressive for that unit .
if they are 85lb injectors , its got to be on the edge .......... be careful . ;)
i keep an eye on the wideband to make sure its not going lean definetely will get an injector upgrade this summer if possible
Your car sounds awesome and seems to run great with the efi setup. Is there anything you would change about it if you could besides injectors? Seems like the way to go for a high hp streetcar.
I'm happy with it, but I have had nothing but problems trying to get my laptop to link to it, they got it to work once. My laptop (toughbook with xp) runs mercury racing software, wolf efi software, megasquirt and more with no issues , so unsure what the problem is. Fortunately most items can be done from the handset that comes with the unit. I just put a transbrake in the 4l80, and new tires. Hoping to get down to 9.40's with it, and still get 20 mpg!
Which kit do you have and when you get the software issue fixed can ypu post up what was wrong ?
Have you tried the lap top to your 6530 box for tuning instead of the FI tech system?
I use the same computer for the msd programming and the micosquirt 4l80 program. Actually taking it to pbir tomorrow night, got new mickey Thompson pro bracket drag radials, d a shocks front and back, and just put a transbrake in. Hopefully I get a new best et tomorrow night.
I need to call them and see if this can be used with an LS engine , even if I need to use an MSD box for the ignition I would be ok with that if they will work together ?!?
it can be used with ls as long as you are running a carbureted intake manifold but it wil not run cop ignition you"d have to use msd for that
