Like to know how you like it or are they a good procharger.Lust like to get some feed back?
thanks
thanks
I ran one with an MFI setup. Run some sort of a filter on the oil feed line. I got a little piece of crud in the spray hole and it took the blower out. Aside from that, unless you are getting a smoking deal, I would step up to an F series blower. Thye will still make some pretty good power. You CAN NOT over spin them. They have a max RPM and the will come apart if you push it past that point.Like to know how you like it or are they a good procharger.Lust like to get some feed back?
thanks
