I thought it would be nice to start a thread discussing handy tool tips, especially some that may be "obscure" and not well known but handy working on our cars.
My contribution is this:
Ever have to perform "surgery" on a wire harness that has some heat shrink sleeve around it? I found a "Stitch Ripper" tool that is used by seamstresses to open up stitched seams works great.
Just get the pointy end started under the shrink and you can carefully work it along the length of shrink sleeve to get it off or just open up a section if that's all you need.
You still need to be careful not to cut into any of the insulation on the covered wires and sometimes need to work it a short section at a time. And if you're not careful, you will end up with the pointy end stuck in your hand..... But I've found this to be the quickest and best way to get under shrink sleeve. Either order one online (their dirt cheap) or any fabric store such as Joann's Fabrics and some hobby shops have them.
