1 - 19 of 19 Posts
Where have guys gotten hand crank rotary barrel pumps compatible with E85?
I’ve been searching all over and they seem to range anywhere from $100-800+.
So many say they are e85 compatible but then in the info at the bottom it says only up to e15.
Some don’t specify at all.
I don’t think I’ve found a single one that says e85 compatible
I don’t want some plastic pos but not trying to spend a ton. Preferably I’d like to be in the 250 or less range
Also trying to find something that comes with a hose and nozzle
It's electric, but does this fit your needs?
does anyone know if this can be left on a drum all the time? as in does it seal the drum to protect the contents?
Discussion Starter · #8 ·
I saw that one on summit but it didn’t have very good reviews
I wouldn’t trust that any of them do. It doesn’t take but a couple min to pull the pump out and seal the barrel up
I have a plastic POS I've been using for 2 years with methanol with zero issues. Buddy of mine went to a farm store and just bought what they had and been using it for 4 years no issues.
Got a brand or part number or anything?
This is the one I have. Doesn't show as available now. I would think any all plastic pump should work but that's a guess on my part.
0615200850043 amarine made
Discussion Starter · #12 ·
Finally found what I was looking for
Lumax Lx-1318
The hose looks Cheese ball so
Also buying this hose
Fill-Rite FRH07512
And this nozzle
Fill-Rite 5200F1790
Here's what I use and it's been great so far. I run methanol. Not a hand pump but it works:
Discussion Starter · #16 ·
I just found that one late last night. Heading to pick one up here in a little while. Trying to setup so I can pump straight into the car so I’m still gonna have to buy a hose and nozzle and maybe some fittings since it looks like there aren’t threads on the end of the discharge tube
1 - 19 of 19 Posts
