1 - 10 of 10 Posts
burnt front cap and firewall.
will paint ever stick again?
how would you want prep
for paint if so?
thanx,
chays
High speed wire brush, power wash than sand with 180 or so and etch prime it then seal it with a sealer primer. The sealer will give you a good surface to paint over after sanding it with 320. Good as new... I have done it a couple times and worked great and looked like new...
stay away from soda blast! conventional media or plain old sanding methods will do fine, as said before, use an etching primer and a sealer. you'll be fine
1 - 10 of 10 Posts
