1 - 6 of 6 Posts
I have a welder helping me tig my cage together. When installing the gusset do they need to be welded on both sides? seems like one side would be enough. Does the entire triangle need to be welded or just the flats leaving a un welded spot in the point? thanks for any info.
I always weld both sides of the gussets, only way I feel comfortable with them
Thanks for the replies welded both sides. called the division inspector and he said one side was ok..
Passed my cage inspection, inspector said he likes to see them welded on one side. He said to much heat welding both sides.
1 - 6 of 6 Posts
