1 - 7 of 7 Posts
This is my first time to run aluminum rods and after 15 dyno pulls tuning a twin turbo efi engine, i decided to take the engine apart just to look at it. There was one rod where i took the rod bolt out and a small almost 3 quarter round (sliver) of aluminum thread came out as i unscrewed it. Is this common ?
dont think its common, i do know that alot of guys will replace aluminum rods after running them on the dyno if its alot of pulls.
No that is not common, post a pic if you can,,,, call GRP and talk to them
I HAVE seen GRP's that had what you describe in the threads new. I always clean them well before assembly. Was this piece very thin ? are you sure it was a thread pulling out?? DID you oil the bolts on assembly??
No cause for alarm, i talked to grp and he told me it was most likely when the steel inserts were pressed into the rod cap it peeled a small bit of aluminum from the pressing in of the insert. . It did come out as just a sliver and did not appear to come from the threads. It also showed up under the rod bolt head anyway when i took the rod bolt out. Couldnt been part of thread then.
I should have called grp first instead of alarming people about this . The rods are working great and great service for grp.
I run GRP 5300's and I remember seeing a hair or two as I cleaned them when new. Never thought twice about running them.
1 - 7 of 7 Posts
