LSx 427 still on hydraulic (morel), 50 miles on this motor, few dyno pulls and 1 full pass. Tearing it down to check it out and the cam has grooves like record on it. It is a new bullet cam 63x lift. lifter rollers look fine but the cam is grooving, I can feel them a bit with my nail. First try with Bullet cams, is it done for?
Also the PT88/98 is on a f trim wheel with a .92 A/R. Really laying over at 6500 rpm at 19 psi. I am pretty sure the back pressure is getting pretty high with this small turbine setup.
Should I go 1.3x or 1.00 Turbine with the g trim wheel?
Car only ran [email protected], 7500 Ft DA, 19 psi, car is heavy. She needs a diet and some more horsepower.
