1 - 9 of 9 Posts
Putting a griner brake in a th400 (latest one 34g10.1) and also have a coan aluminum direct drum. says to drill the .060 bleed hole in the direct ,but It has three check balls in the edge of the drum already. Is this enough or should I also drill the bleed hole? thanks in advance
Discussion Starter #2
only reason i ask is I cant get a hold of Griner, it just rings and says noone is here and can't leave a message
I drill a .060 hole in those drums. Hope this helps
1 - 9 of 9 Posts
