1 - 4 of 4 Posts
i built a grill from a 250 gallon tank, i need a propane and have tried to make them out of black pipe and it is just not working right, anyone on here have any ideas or give me some advice how to make a propane burner. thank you for any help
not sure on this type set up but on a normal gas grill the burner has to have an air shutter in the beginning of the tube, maybe look at a fireplace log lighter they have a air shutter built in the end and then you thread the pipe into that.
the pipe is 32 inches with 2 1/8" holes every inch, it has a 90 on the end and a 15 inch pipe which connects air mixture with the orfice, it is 3/4 pipe
1 - 4 of 4 Posts
