1 - 20 of 26 Posts
Prep sol or brake cleaner!!!
wd-40 if its fresh
0000000
sand blast it . jk they sell some stuff at home depot in the paint section called grafitti remover that wont hurt the paint
WHAT NOW ?
home depot or paint store, its called goof off.
brake cleaner was my first thought, but it didn't even touch it
Ouch. That should have done it. Might try 3M's "General Adhesive Remover". It'll usually remove aerosol type paints along with bubble gum from fabric and several other impressive feats, that you would think impossible to pull off.
It's available in aerosol or squirt can. I have had better luck with the squirt can. More concentrated.
Philippians 4:13
9mm or .45 should do the trick. But in all seriousness all these they mentioned are good tips, hope it works for you.
Carb choke cleaner on a rag and try that. watch your paint though
1 - 20 of 26 Posts
